BKT7300 NOT ACTIVATED IN BBLOGGER (SOLVED) - Printable Version
+-- Forum: IC7300BKT Cat Control for ICOM IC-7300 (https://www.maniaradio.it/forum/forumdisplay.php?fid=32)
+--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=34)
+--- Thread: BKT7300 NOT ACTIVATED IN BBLOGGER (SOLVED) (/showthread.php?tid=588)
BKT7300 NOT ACTIVATED IN BBLOGGER (SOLVED) - F4DAS - 12-25-2023
Hello,
I installed BKT73000 but it does not work with bblogger.
In the tools tab, bblogger BKT is not enabled.The duar bridge driver is installed. The CI_V 88H transceiver does not work.
I stay on the CI_V94h function and it works a little better with some QSO passed in FT8 but not registered by bblogger.
If you can help me, thank you.
RE: BKT7300 NOT ACTIVATED IN BBLOGGER - iz2bkt - 12-26-2023
you need to install the updated version of BBLogger (download from https://www.aribusto.it/bblogger.htm
If you encounter any other issues with BBLogger, please write to the group https://groups.google.com/g/bblogger.
All version of BBLogger are available on https://www.maniaradio.it/en/bblogger-test.html
RE: BKT7300 NOT ACTIVATED IN BBLOGGER - F4DAS - 12-27-2023
So I downloaded the latest version and it works.73 of GUY,F4DAS.
