Ho to localize IC7300BKT - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7300BKT Cat Control for ICOM IC-7300 (https://www.maniaradio.it/forum/forumdisplay.php?fid=32) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=34) +--- Thread: Ho to localize IC7300BKT (/showthread.php?tid=581) |
Ho to localize IC7300BKT - iz2bkt - 08-30-2023 How to localize the program: 1. Go to the installation folder ( Ex. C:\IZ2BKT\IC7300BKT Icom CAT Control ) 2. Copy the file english.lng to the Documents folder 3. Rename the file english.lng with the name of the translated language (ex. spanish.lng) 3. Run BKTLocalize (https://www.maniaradio.it/dati/BKTLocalize.zip) 4. Select the file created in step 3 5. In the cells of the right column, write the translation or leave the cell empty to not translate the sentence 6. Once the translation is complete, click on [Save and Close] 7. Copy the translated file to the installation folder of IC7300BKT 8. Launch IC7300BKT and in Utility->Configuration click on [Change Language] to select the new language IMPORTANT: Do not replace the special characters % and \ The translated sentence must not be longer than the original one If you want, you can send me the translated LNG file, and I will place it in the program's installation. |
