IC-706 MKII S-Meter Read - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: IC-706 MKII S-Meter Read (/showthread.php?tid=58) |
IC-706 MKII S-Meter Read - sv8ckm - 08-21-2011 Hi, Does IC706_BKT Cat Control for Icom IC-706 supports s-meter read during TX (PO or SWR)? Thank you & 73s Fotis - sv8ckm Re: IC-706 MKII S-Meter Read - iz2bkt - 08-21-2011 sv8ckm Wrote:Hi, Hi Fotis, The hardware of the Icom IC-706 does not support reading SWR and PO ( as the IC-7000 ), for info on the functions not supported you can look here: http://www.iz2bkt.com/forum/viewtopic.php?f=2&t=29 |
