Autogrid setup for udp multicast - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: Autogrid setup for udp multicast (/showthread.php?tid=572) |
Autogrid setup for udp multicast - AB8WD - 05-24-2023 I am running multicast on WSJt 124.0.0.1 2237 works with all others I am being messaged that my grid is not showing up in wsjt I tried to set the autogrid in bktimesync and it shows 2.237 and 2240001 and will not let me edit or fix any ideas also seems timesync is not syncing to wsjt anymore still working on that thanks in advance de ab8wd RE: Autogrid setup for udp multicast - iz2bkt - 05-25-2023 (05-24-2023, 01:39 PM)AB8WD Wrote: I am running multicast on WSJt 124.0.0.1 2237 works with all others Hi, The correct address is 127.0.0.1, not 124.0.0.1 |
