Improve remote connection client/server - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: Improve remote connection client/server (/showthread.php?tid=57) |
Improve remote connection client/server - iz2bkt - 08-15-2011 For a good functioning the network should have a bandwidth of about 150kbps in download and 50kbps for upload. To improve the communication : In the program IC706_BKT : 1 - Disable [Polling] 2 - If there are errors in setting, in Utility- >Configuration manually put the value in Latency time ( try with 500 or more ) In BKTServer : 1 - If you use more than one network card, in IP put the IP address of the network card to use. 2 - In Audio Stream Configuration use low values of bits/sample and sample/sec, increasing the Buffers increases the delay of listening to the audio. |
