Set up WSJT-X for Auto Grid - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: Set up WSJT-X for Auto Grid (/showthread.php?tid=569) |
Set up WSJT-X for Auto Grid - iz2bkt - 04-10-2023 The Auto Grid function in WSJT-X allows you to set a temporary WWL (Worldwide Locator) based on the GPS location detected by BktTimeSync. To use this feature with BktTimeSync, you must meet the following requirements: [ul] [li]Have Microsoft Net Framework 4.8 or a later version installed (which is already included by default in Windows 11).[/li] [li]Activate GPS synchronization and wait for the WW Locator grid value to be displayed.[/li] [li]The WW Locator is sent to WSJT-X only when BktTimeSync synchronizes the time using GPS or by pressing the [Send WW Locator] button.[/li] [li]Sending the WW Locator may fail if there are other software programs that are also using the connection to WSJT-X. If there is an error, BktTimeSync will automatically retry for one minute.[/li] [/ul] The grid sent by BktTimeSync to WSJT-X will not be visible in the WSJT-X configuration but will be used only during transmission. If WSJT-X is restarted, it must be sent again. To configure WSJT-X in this way: ![]()
