how to save TONE setting in memory editor? - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: how to save TONE setting in memory editor? (/showthread.php?tid=566) |
how to save TONE setting in memory editor? - VK2AAF - 03-10-2023 I am trying to save the transmit CTCSS TONE selection in a memory. I set TONE in Tx Ac T. I press ENTER. Then I click SAVE. TONE disappears. So that doesn't work. I set TONE in Tx Ac T. I press ENTER. Then click SAVE and Active. TONE disappears. That doesn't work. How do I save TONE 'on' in a memory? This is not addressed in the Editing Memory Bank area in the HELP file. In case it matters, I can use the live control panel to turn TONE on and off. That works. Help? Thanks 73 de Brian VK2AAF RE: how to save TONE setting in memory editor? - iz2bkt - 03-11-2023 Hi Brian, please watch this video, it is for the IC-7100 but the procedure is also the same for the IC-7000 : http://www.maniaradio.it/forum/imagespers/SalvaTone.mp4 |
