ic-706 on/off - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: ic-706 on/off (/showthread.php?tid=563) |
ic-706 on/off - sv8alq - 02-10-2023 Good evening. I just registered to this program for ic-706. I like some times to work remote from another pc on the same network. The software is connected to ic-706. What i need to do is to connect to remote pc to run the software and put on or off the radio but i cannot see any button in software. Is anybody here tried to do this? thank you. RE: ic-706 on/off - iz2bkt - 02-11-2023 (02-10-2023, 05:16 PM)sv8alq Wrote: Good evening. I just registered to this program for ic-706. I like some times to work remote from another pc on the same network. The software is connected to ic-706. What i need to do is to connect to remote pc to run the software and put on or off the radio but i cannot see any button in software. Hi, The IC-706 does not support software power on/off (unlike the IC-7100 and IC-7300). RE: ic-706 on/off - sv8alq - 02-12-2023 (02-11-2023, 06:39 AM)iz2bkt Wrote:(02-10-2023, 05:16 PM)sv8alq Wrote: Good evening. I just registered to this program for ic-706. I like some times to work remote from another pc on the same network. The software is connected to ic-706. What i need to do is to connect to remote pc to run the software and put on or off the radio but i cannot see any button in software. ok......thank you |
