 Icom IC 706 S-Meter SDR german/engl./ital. - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: Icom IC 706 S-Meter SDR german/engl./ital. (/showthread.php?tid=540)  |
Icom IC 706 S-Meter SDR german/engl./ital. - Elektrolurch - 02-08-2022 Hallo ich habe eine Vollversion und ein IC 706 und würde gerne den S- Meter und die PTT- Taste im Programm benutzen . Das Programm gefällt mir gut. I Desweitern würde ich gerne einen Wasserfall auf meinem Computer darstellen. gibt es hierfür eine Lösung. Grüsse Michael Hi I have a full version and an IC 706 and would like to use the S-meter and the PTT button in the program. I like the program a lot. Furthermore, I would like to display a waterfall on my computer. Is there a solution for this. greet Michael Ciao Ho una versione completa e un IC 706 e vorrei utilizzare l'S-Meter e il pulsante PTT nel programma. Mi piace molto il programma. Voglio anche visualizzare una cascata sul mio computer. C'è una soluzione per questo. saluta Michele Hallo EN RE: Icom IC 706 S-Meter SDR german/engl./ital. - iz2bkt - 02-09-2022 Hi Michael, unfortunately, the IC-706's CI-V command set is very poor and many functions cannot be achieved via the computer interface. To find out which functions your IC-706 supports go to these links: https://www.maniaradio.it/en/ic706_bkt.html https://www.maniaradio.it/forum/showthread.php?tid=26 S-Meter is only available for IC706-MKII/G. To use the PTT command you have to build this small interface https://www.maniaradio.it/en/interface.html -> PTT Interface  |
