Helpfile available as a PDF? - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: Helpfile available as a PDF? (/showthread.php?tid=50) |
Helpfile available as a PDF? - g0vax - 07-06-2011 Hi there, Is the helpfile available as a PDF so it can be printed out? Best Wishes Brian G0VAX Re: Helpfile available as a PDF? - iz2bkt - 07-07-2011 Hi Brian, You can download the PDF manual from http://www.iz2bkt.com/ic706bkt3en_download.html (IC706_BKT User Manual). You can display the guide also by pressing F1 from the program. |
