 IC-7300 does not connect at 115200 BAUD - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7300BKT Cat Control for ICOM IC-7300 (https://www.maniaradio.it/forum/forumdisplay.php?fid=32) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=34) +--- Thread: IC-7300 does not connect at 115200 BAUD (/showthread.php?tid=498)  |
IC-7300 does not connect at 115200 BAUD - iz2bkt - 01-03-2021 The connection speed with the Icom IC-7300 can reach 115200 BAUD, if it doesn't work enter in the radio configuration in Menu->SET->Connectors->CI-V->CI-V USB Port and select Unlink from [REMOTE], exit the configuration with the back key and switch the transceiver off and on again.  |
