cannot open setup page - SOLVED - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: Free Software (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: cannot open setup page - SOLVED (/showthread.php?tid=488) |
cannot open setup page - SOLVED - Ger - 10-28-2020 I've been using BktTimeSync for many years. Am satisfied with it and recommend it to others as well. But recently I can no longer open the setup window. Just uninstalled and reinstalled the software. But the problem remains. RE: cannot open setup page - iz2bkt - 10-28-2020 (10-28-2020, 11:00 AM)Ger Wrote: I've been using BktTimeSync for many years. Am satisfied with it and recommend it to others as well. But recently I can no longer open the setup window. Just uninstalled and reinstalled the software. But the problem remains. Hi, first check that the program is not minimized in the try bar ![]() If not try this:
RE: cannot open setup page - Ger - 10-28-2020 Thanks a lot, working as before. You forgot only to say that the PC need a restart, 73 |
