BkTimeSync No GPS Time - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: BkTimeSync No GPS Time (/showthread.php?tid=459) |
BkTimeSync No GPS Time - Wirezfree - 01-06-2020 Hello, Please can you help.?? I have GPS Chipset: U-blox 8 from Amazon: http://tiny.cc/UBLOX-8-GPS I installed what I believe is the "standard" driver, it showed "COM4" in device manager. I installed VisualGPSView and it immediately started working when I selected COM4 I let it run for a few hours, no issues. I installed BkTimeSync and selected COM4, but it appears there is no detection of GPS.? No data is showing in the GPS area of application window..?? Any suggestions would be appreciated.... Thank You BkTimeSync Device Manager VisualGPS Working RE: BkTimeSync No GPS Time - iz2bkt - 01-07-2020 Hi, could be the USB / COM driver is not compatible with BktTimeSync, try changing the parameters of the COM port. |
