Easy to make CI-V cable - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: Easy to make CI-V cable (/showthread.php?tid=458) |
Easy to make CI-V cable - WT9M - 12-19-2019 You can add this to the list of home made Icom CI-V cables . I just made this one and it worked. I used a different kind of $2 usb to ttl board because I had one ( silicon labs CP210x is what it says ) Here is schematic - only need a resistor and diode. Larry WT9M RE: Easy to make CI-V cable - iz2bkt - 12-20-2019 Hi Larry, Thank you very much. |
