problem connection - Printable Version
+-- Forum: BktRemoteSuite (Deprecated) (https://www.maniaradio.it/forum/forumdisplay.php?fid=29)
+--- Forum: BktRemote Suite (https://www.maniaradio.it/forum/forumdisplay.php?fid=27)
+--- Thread: problem connection (/showthread.php?tid=423)
problem connection - f5sjf - 06-16-2019
Helllo, my name is jerome and call F5SJF.
I have problem for connect my ic7100 with my computer et use bktAndroid.
On my PC BKTServer 2.2.0
On my smartphone BktRemot v1.5.3
Run BktServer ok
Run BktRemote and click "Connect"
on BktServer is good: "Connection Etablished" but on my smartphone: "Error Occured: An error has occured in sub:main_vvvvvvvvvvvvvv4 (java line:2089)  java.lang.ArrayIndexOutOfBoundsException: length=10;index=10    Continue?
If click Yes, it's possible to continue but no frequency or other functions and if click "NO", BktRemot going to closed.
On my smarthphone is Xiaomi MIMAX2 with android MIUI10
Please help me
RE: problem connection - iz2bkt - 06-16-2019
Hi Jerome,
this error means that the smartphone does not reach the server, verifies that the IP configuration is correct and the firewall is open for BktRemoteServer
