How to load registration key - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7300BKT Cat Control for ICOM IC-7300 (https://www.maniaradio.it/forum/forumdisplay.php?fid=32) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=34) +--- Thread: How to load registration key (/showthread.php?tid=422) |
How to load registration key - iz2bkt - 06-10-2019 Method 1: 1. Unzip the registration key file received by email in the program folder (default: C:\IZ2BKT\IC7300BKT Icom CAT Control) 2. Run the program IC7300BKT, the key will be automatically loaded and deleted from the folder. Method 2: 1. Unzip the registration key fileĀ <call.ic7300bkt.bkt> received by email in a folder. 2. Run the program IC7300BKT 3. On Utility tab click on [Register the program] 4. On registration dialog click on [I have the key, load it] 5. Select the unzipped file in the folder used in step 1 and press [Open] 6. At the next run the program will load the key into its database and delete it from the folder. To check if the program is registered look in the title bar: |
