Connect using VSPE Virtual Serial Ports Emulator - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Connect using VSPE Virtual Serial Ports Emulator (/showthread.php?tid=41) |
Connect using VSPE Virtual Serial Ports Emulator - iz2bkt - 04-25-2011 If you can't connect to the rtx with the program could be a drivers problem, especially if you use USB interfaces, to resolve this problem, you can try to use a virtual COM port: 1) Download the Virtual Serial Ports Emulator VSPE ( free for 32 bit operating systems ) from here: http://eterlogic.com/Products.VSPE.html 2) Install and run VSPE 3) Power On the RTX From VSPE: 4) From the Menu Device select Create 5) In Device Type select Splitter and click Next 6) In Virtual Serial Port select a COM free (or leaves that proposal from the program) 7) From Date Source Serial Port select the COM connected to rtx 8) Un-check Read-only and Redirect modem registers 9) Click End From IC7000BKT: 10) Launch the program IC7000BKT ( version 1.15.0 or higher ) 11) Go to Utility->Configuration->Com configuration 12) In Port select the COM created in point 6 13) In Serial Port Mode select MODE 2 14) Confirm all with OK |
