Using IC706_BKT with JTDX, WSJT-X and MSHV - Printable Version
+-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3)
+--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4)
+--- Thread: Using IC706_BKT with JTDX, WSJT-X and MSHV (/showthread.php?tid=404)
Using IC706_BKT with JTDX, WSJT-X and MSHV - iz2bkt - 12-16-2018
Guide to using IC706_BKT with WSJT-X, JTDX, MSJV:
IC706_BKT Version 4.21.0 and later:
- In IC706_BKT go to Utilities -> Configure
- Enable LAN Protocol on port 52002
- Confirm with OK
In WSJT-X or JTDX:
- Go to File -> Settings -> Radio
- In Rig select DX Lab Suite Commander
- Confirm with OK
In MSHV:
- Go to Options -> Interface Control
- In the Network box -> Server type 127.0.0.1 and in Port type 52002
- In RIG select DX Lab Suite Commander
IC706_BKT versions prior to 4.21.0:
- Download and install BktNetInterface
- Start BktNetInterface
- Select the CAT in use (IC706_BKT)
- If you want the connection to start automatically when you open the program, check "Auto-start in system tray"
- Click "Start"
- Start JTDX or WSJT-X
- Go to "File" -> "Settings" -> "Radio"
- In "Rig" select "DX Lab Suite Commander"
- Close with "OK"
To start BktNetInterface with the CAT:
- Start IC706_BKT
- Go to "Utility" -> "Startup"
- In "Description" write "BktNetInterface"
- In "Program" select "BktNetInterface.exe" from the installation folder
- Click "Save"
It is recommended to start IC706_BKT first and then JTDX, WSJT-X or MSHV.
