Communication Problems - COM error - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Communication Problems - COM error (/showthread.php?tid=4) |
Communication Problems - COM error - iz2bkt - 10-03-2010 For communication errors try this: - Install the latest version from http://www.maniaradio.it/en/download.html. - check these settings in Icom IC-7000 Set-Mode: CI-V Baud Rate = Auto ( in some cases you need to select the speed set in the program ex. 19200 or 9600 ) CI-V Address = 70h CI-V Transceive = OFF - If use a USB interface check that the USB driver are correct and that the port you selected in the programme corresponds to USB interface. If you can't find the correct USB drivers, try I2WQ's interface: https://www.maniaradio.it/forum/showthread.php?tid=553 - try to change Serial Port Mode: MODE 1: preferable for USB interfaces MODE 2: preferable for serial interfaces on board or PCI ( also for RigTalk and RigBlaster ) - try to use BKTRS232 driver: - try to switch ON/OFF the RTS and DTR signal - try to change BAUD speed - Verify that there are not running other programs that use the same COM port IF ALL THIS DOES NOT WORK LOOK HERE:https://www.maniaradio.it/forum/showthread.php?tid=41 |
