Registration not working... (SOLVED) - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Registration not working... (SOLVED) (/showthread.php?tid=396) |
Registration not working... (SOLVED) - mmonti - 12-04-2018 I am trying to register with the key I was sent after donating. I have tried both methods of registering. (copy key file to location, and using the register button in the program.) both accept the key and say to restart the program. But on restart it says its not registered. It does show my call sign and correct Operator name at the bottom of the screen. But at the top it says "1.29.1 - Free Version - RTX: IC-7000" Is there a full version I need to DL ? or am I doing something wrong ? Windows 10 running on a MSN motherboard with intel i5 processor. 16gigs ram. Thanks for any Help you can offer. Michael RE: Registration not working... - iz2bkt - 12-05-2018 Hi Michael, Please give me the call with which you registered for the Full version. Thank you RE: Registration not working... - mmonti - 12-05-2018 (12-05-2018, 07:19 AM)iz2bkt Wrote: Hi Michael, Sorry, that's is basic info I forgot to give. My call is KN4MBF Thanks. RE: Registration not working... - iz2bkt - 12-05-2018 I tried the key that was sent to you and works as full. I sent you the key, please try to load it If it does not work, please reply to the email where you received the key by attaching the IC7000BKT.INI file that you find in the installation folder RE: Registration not working... (SOLVED) - mmonti - 12-05-2018 (12-05-2018, 01:52 PM)iz2bkt Wrote: I tried the key that was sent to you and works as full. That one works, Thank You ! |
