Memory naming - Printable Version
+-- Forum: IC7000BKT Cat Control for Icom IC-7000 - will no longer be updated and will be replaced by CatBkt2 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5)
+--- Thread: Memory naming (/showthread.php?tid=392)
Memory naming - F4VPJ - 10-03-2018
I'm sure the answer will be on here somewhere but not found it yet?!
IC7000 memory setting up frequencies and adding 'Description' to each BUT that doesn't seem to appear on the memory bank on the radio, is there a way of getting the description to appear as a memory name on the rig display (for instance as repeater indent., '2mFM calling' etc.)?
Thanks
Rob F4VPJ
RE: Memory naming - iz2bkt - 10-06-2018
Select menu M-2 and press F-1 ( MEM )
RE: Memory naming - F4VPJ - 10-08-2018
(10-06-2018, 01:39 PM)iz2bkt Wrote: Select menu M-2 and press F-1 ( MEM )
Ideal!  Thank you!
73 de Rob F4VPJ
