JT65-HF to IC7000BKT Connection - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: JT65-HF to IC7000BKT Connection (/showthread.php?tid=39) |
JT65-HF to IC7000BKT Connection - ZL2AHB - 04-13-2011 Hi Mauro Thanks for responding to my request for a timed start/stop on the recorder function. ![]() I finally cracked the character code to join the forum! ![]() JT65-HF shows the frequency from IC7000BKT using the "Commander" check box but does not change the frequency when clicking on a different frequency using the drop down list on JT65-HF nor does it operate the PTT. I think it does the same with Commander and that only HRD can change the frequency and operate PTT. Is there something I am not doing? I tried starting MyDDE but could not get it to start with IC7000BKT and JT65-HF running. MyDDE works well with Orbitron though. 73 de Lorne Douglas ZL2AHB / ZL3LSD Re: JT65-HF to IC7000BKT Connection - iz2bkt - 04-14-2011 Hi Lorne, welcome to the forum. What you have written is correct: JT65-HF supports these functions only with HRD MyDDE is only for use with Orbiton. Re: JT65-HF to IC7000BKT Connection - iz2bkt - 04-23-2011 ZL2AHB Wrote:Hi Mauro Hi Lorne, is available the Version 1.15.0 where it is possible to program the automatic recording by the function skeds. |
