Program registration - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7100BKT Cat Control for Icom IC-7100 (https://www.maniaradio.it/forum/forumdisplay.php?fid=15) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=24) +--- Thread: Program registration (/showthread.php?tid=380) |
Program registration - ok1vvt - 02-09-2018 Thank you for a great program, I received the activation key file and when I am trying to register program i get a notice Error 6 in the load the key Is there any way how to fix it ? 73! and best regards Vasek OK1VVT RE: Program registration - iz2bkt - 02-10-2018 Hi Vasek, this error indicates that the key is not for the program you are using. The key you received only works with the IC7100BKT program, if you use IC7000BKT or IC706_BKT you must request another key. RE: Program registration - F4VPJ - 10-02-2018 Hi Mauro Thank you for an excellent program, I received the key and activated yesterday and pleased to see it communicating happily with my IC7000. Many hours of happy programming ahead I think!! ![]() 73 de Rob F4VPJ RE: Program registration - iz2bkt - 10-02-2018 Thank you Rob. |
