BktTimeSync Failed to Start - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: BktTimeSync Failed to Start (/showthread.php?tid=372) |
BktTimeSync Failed to Start - Rick - 11-22-2017 The last couple of mornings BtkTimeSync has failed to start at Windows bootup? OS Windows 7 Pro 64 BktTimeSync Version 1.9.1 Time from an enabled GPS Sync Every 5 minutes Error Msg: Last Sync :Wednesday, November 22, 2017 07:37:01 Failed to set the local time After more than 30 minutes it had still not tried to resync. I stopping BktTimeSync in Task Manager (it was taking 25% CPU) and restarted it. Since the restart it has run correctly. Since this is a new program for me I have been monitoring BktTimeSync on the task bar. When I hovered over the icon I saw the error message? I'm curious if anyone else has seen this? Thanks, Rick VE7TK RE: BktTimeSync Failed to Start - iz2bkt - 11-23-2017 Hi Rick, It could be a problem of the serial port, try to uncheck "Always connected to GPS", "Max Error" in 1 second and sync evry to 60 minutes |
