GPS QRP-LAB no run - Printable Version
+-- Forum: Free Software (https://www.maniaradio.it/forum/forumdisplay.php?fid=28)
+--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22)
+--- Thread: GPS QRP-LAB no run (/showthread.php?tid=349)
GPS QRP-LAB no run - EA4GHB - 05-22-2017
Hi all.
I try to use Bkt timeSync with a qrp-lab gps. it´s a YIC5.  but no run.
The program work good with a Ntp server, but not in gps mode.
My OS is win 8.1 and gps is conected to PC like this:
1PPS--------------pin 1 of DB9
TxD--------------- pin 2
RxD---------------pin 3
Win recognice the device, and assing a COM. but  Bkt TS no run.
what i´m doing wrong?
Thanks for help.
73!
Alberto-EA4GHB
RE: GPS QRP-LAB no run - iz2bkt - 05-22-2017
Please, enable BktTimeSync Diagnostic Log and post the result
RE: GPS QRP-LAB no run - EA4GHB - 05-23-2017
Hi Mauro,
I paste diagnostic log:
Last Sync :Monday, May 22, 2017 20:30:28
Please select NTP and/or GPS sync mode
Enable GPS is select and I press SYNC NOW, but diagnostic log do not write anything more.
Thanks.
Alberto
RE: GPS QRP-LAB no run - iz2bkt - 05-23-2017
1. Check Diagnostic Log
2. Click Sync Now
3. Close BktTimeSync
4. Paste Diagnostic Log
Thank you
SRI Mauro,
Paste now. Thanks.
Windows Versione: 6.02
BKTTimeSync Versione: 1.8.2
NTP Server:
NTP Porta: -1
NTP Offset:
NTP ON: 0
Autostart: 1
Start in tray: 0
Sync all'avvio: 0
Sync ogni: -1 minuti
Sync massima: 12 ore
GPS Porta: 4
GPS Baud: 9600
GPS Bit: -1
GPS Bit di stop: -1
GPS Parità:
GPS RTS: 1
GPS DTR: 1
GPS Offset:
GPS Always Connected: 0
Sequence: 1
Tue May 23 16:02:07 2017 --> Sync start P1
Tue May 23 16:02:07 2017 --> Sync GPS COM open
Tue May 23 16:02:08 2017 --> Sync start P1
Tue May 23 16:02:09 2017 --> Sync start P1
Tue May 23 16:02:10 2017 --> Sync start P1
Tue May 23 16:02:11 2017 --> Sync start P1
Tue May 23 16:02:12 2017 --> Sync start P1
Tue May 23 16:02:13 2017 --> Sync start P1
Tue May 23 16:02:14 2017 --> Sync start P1
Tue May 23 16:02:15 2017 --> Sync start P1
Tue May 23 16:02:16 2017 --> Sync start P1
Tue May 23 16:02:17 2017 --> Sync start P1
Tue May 23 16:02:18 2017 --> Sync start P1
Tue May 23 16:02:18 2017 --> Sync GPS COM port closed
RE: GPS QRP-LAB no run - iz2bkt - 05-24-2017
The GPS does not send any data to the program, I don't know if it's either the links or the configuration of GPS/COM because I never tested this GPS model. You can experiment by communicating with a communications program on serial ports such as hyperterminal
