VFO B stays in Memory mode - Printable Version
+-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5)
+--- Thread: VFO B stays in Memory mode (/showthread.php?tid=348)
VFO B stays in Memory mode - oe1gqa - 05-11-2017
When I switch off the memory mode ( memory mode was FM split ) then the VFO B stays showing the split frequency of the memory, When I press VFO B and then VFO A again then it shows the correct VFO B frequency
RE: VFO B stays in Memory mode - iz2bkt - 05-12-2017
In the IC-7000 you can read only the values of the active VFO, then you cannot update the status until the activation of the VFO interested.
