Encountered an improper argument - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Encountered an improper argument (/showthread.php?tid=342) |
Encountered an improper argument - herbpk - 01-05-2017 Hello: I "updated" to the latest version and I have been experiencing program crashes since. If I open the program with the IC-7000 in operation, I get "Error in the initialization of audio support". When I acknowledge the error, an audio setting dialog box opens but when I check "enable audio", I get the same error again. The other areas are not available for any data input. Closing, the program crashes. If I try to open the program from the start menu (as alternative to the desktop shortcut) I get an alternate box stating "encountered improper argument" . I can close the program from here without a complete "crash" but still no IC7000BKT program. Anyone have any ideas? 73 herb Re: Encountered an improper argument - iz2bkt - 01-06-2017 Hi Herb, you probably have some problem with the sound card (perhaps it is blocked by another software), try disabling the audio support : Utility->Configuration->Audio and uncheck Enable as audio support. If you don't solve it, uninstall the program, delete the installation folder (default c:\iz2bkt\IC7000BKT Icom Cat control) and reinstall IC7000BKT. |
