 BktTimeSync - where has the screen gone??!! - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: BktTimeSync - where has the screen gone??!! (/showthread.php?tid=329)  |
BktTimeSync - where has the screen gone??!! - g4urt - 11-22-2016 Hi, I have found this program via Moon-Net. I have had problems in synching my computers for WSJT JT65b (Moonbounce) use where the correct time is vital. I have installed in my back-up laptop (Windows7) and it works a treat - theinformation screen comes up and I can sync when I want to, change the server etc. I then installed it in my main computer (also Windows 7) and it worked fine. However, at sometime the information screen has gone. The program is still installed and I have enabled the clock to run on the desktop - it is still there. If I double click on the icon on the desktop a PUW comes up asking me if I 'would allow the following program from an unknown publisher to make changes..yes / no'. If I hit 'yes' nothing happens. I have tried uninstalling then re-installing but I cannot get the screen back. When I un-install it tells me to stop BktTimeSync from running - this is not possible as I cannot get to the screen in question. So, 2 questions... 1/ If the desktop clock is working does this mean that the program is fully installed and it is keeping my computer at the correct time? 2/ How do I recover the information screen so I can manually sync, change servers etc? If all else fails then it will have to be system restore to a previous date but I really do not want to this!!! Regards, Peter G4URT Re: BktTimeSync - where has the screen gone??!! - iz2bkt - 11-23-2016 Hi Peter, try double click on the icon in the system-try Re: BktTimeSync - where has the screen gone??!! - g4urt - 11-23-2016 Hi Mauro, Thanks for getting back. This program was HIGHLY recommended by several EME operators who use it with GPS modules which is what I will want it for - internet access is a bonus! If I double click on the Icon I get a Pop Up Window that says 'Do you want the following program from an unknown publisher to make changes to this computer? YES / No. I select YES and I get back the desktop screen - no information screen. If I select the program from my Downloads it allows me to install it but again I do not get the information screen. I have tried running it as an Administrator - no success. I switched the computer off last night and the clock has now gone from the desktop. If I go to my C drive I see that there are various BktTimeSync files. If I double click on BktTimeSyncStart I get the same pop up window and no screen. If I click on BktClock the desktop clock re-appears and is correct to the second. Does this mean that BktTimeSync is working OK to sync the computer for WSJT? Very strange!! Peter G4URT Re: BktTimeSync - where has the screen gone??!! - iz2bkt - 11-23-2016 Hi Peter, BktClock displays the time on the desktop but does not synchronize your PC's clock. Try this: 1. Stop BktTimeSync and BktClock 2. Start Regedit 3. Download this file http://forum.maniaradio.it/imagespers/bkttimesync_clear.zip 4. Open the zip file and run bkttimesync_clear.reg 5. Confirms all requests from Windows 6. Start BktTimeSync Re: BktTimeSync - where has the screen gone??!! - g4urt - 11-26-2016 Mauro, Hi - now all OK! I did not want to play with the registry so I went for a system restore to a point before I loaded BktTimeSync. This has cured the problem and I now have the main screen back. I hope that this may be of help to anyone else having the same problem. Now to go to Windows Update and reload a lot of updates.... Many thanks and 73, Peter  |
