CW keying - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7100BKT Cat Control for Icom IC-7100 (https://www.maniaradio.it/forum/forumdisplay.php?fid=15) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=24) +--- Thread: CW keying (/showthread.php?tid=283) |
CW keying - DK1KW - 09-24-2015 Hi, is it possible to use BKT7100 as a CW keyer for the IC-7100? Can I run the CW memories with BKT7100? 73 Werner DK1KW Re: CW keying - iz2bkt - 09-25-2015 DK1KW Wrote:Hi, Hi Werner, the IC-7100 has not a software command to transmit the memories CW. A CW keyer will be available in future versions of IC7100BKT, in the meantime, you can program the Custom Key for sending phrases CW: enable Full BK-IN o Semi BK-IN and use the command 17 (pag. 20-4 IC-7100 Advanced Instruction Manual) for Custom Key. Ex. for sending CQ CQ in Custom Key Command put: 1743514351FF |
