IC7100BKT and MyDDE2 - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7100BKT Cat Control for Icom IC-7100 (https://www.maniaradio.it/forum/forumdisplay.php?fid=15) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=24) +--- Thread: IC7100BKT and MyDDE2 (/showthread.php?tid=255) |
IC7100BKT and MyDDE2 - zozoka - 05-11-2015 Hello All weekend tried to figure out how to work with orbitron and IC7100 Installed mydde2 , and orbitron sends the rx and tx freq change (doppler) to the radio, but radio change every second from vfoA to vfoB (where vfoA is the RX and vfoB is the TX freq) - so can't use it at all... My 857 radio and the orbitron program with wispdde , orbitron sends the rx and tx to radio ; on radio i'm on rx freq all the time , and it change to the tx freq only when i tx the radio. 73 Zoli Re: IC7100BKT and MyDDE2 - iz2bkt - 05-12-2015 Hi Zoli, MyDDE is an old project that should be updated, however, go into MyDDE options and check Update only RX VFO Re: IC7100BKT and MyDDE2 - zozoka - 05-13-2015 Thanks Mauro Tried right now, but if i check update only rx vfo, than the tx frequency isn't updated....only the rx There is a possibility to have only tx updated ? Regards Zoli |
