RF Gain for RX320D - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: CatBkt Cat Control using HamLib - will no longer be updated and will be replaced by CatBkt2 (https://www.maniaradio.it/forum/forumdisplay.php?fid=6) +--- Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=8) +--- Thread: RF Gain for RX320D (/showthread.php?tid=247) |
RF Gain for RX320D - ZL2AHB - 04-10-2015 Hi Mauro I have been starting to use my old TenTec 320D receiver as a second receiver and I don't need elaborate software to control it so thought I could use CatBkt and as I expected it does most things except it does not have an RF gain slider on it for the RX320D. I have tested N4PY's software as a trial which provides the RF slider (or is it just AF?). I turn the N4PY software off with the the audio left on. When I start CatBkt the audio is at the correct level. Possible to add this to CatBkt? or maybe I just have not found it ! :oops: Thanks & 73Lorne ZL2AHB Re: RF Gain for RX320D - iz2bkt - 04-10-2015 Hi Lorne, sorry but CatBkt is built around the hamlib (open source project) that since 2012 has not been updated, so I'm seriously considering abandoning the development of CatBkt. |
