Quickset - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Quickset (/showthread.php?tid=240) |
Quickset - G0IIQ - 03-04-2015 When using quickset if I click on one of the buttons for a local repeater the frequency and everything changes correctly but after approximately 2 seconds the S meter on the rig and the software show a full reading and there is a loud hissing from the Icom IC7000 just fractionally turning the Volume up or down on the Rig rectifies the problem Re: Quickset - iz2bkt - 03-04-2015 Please, send me as MP the file quickset.dat Re: Quickset - iz2bkt - 03-05-2015 I did not receive the attachment, please try again. Thank You. Re: Quickset - iz2bkt - 03-05-2015 I sent you a PM with the modified quickset.dat file. The problem is that you have stored the RF value to zero |
