Program crashes when attempting to load registration key - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 - will no longer be updated and will be replaced by CatBkt2 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Program crashes when attempting to load registration key (/showthread.php?tid=230) |
Program crashes when attempting to load registration key - ZL4LV - 01-19-2015 I have received the registration key ZL4LVIC7000BKT.bkt and installed it in the IC7000BKT Icom cat control folder as instructed. When attempting to register the program it crashes with a Windows error message then restarts without being registered. The registration key file has also been deleted. I have the latest version of the program installed. I have made several attempts with the same results. I have Norton Security installed, Windows 7 Pro in use. I have since tried it on another computer and the registration was successful. I suspect Norton is the problem, any suggestions? Peter ZL4LV Re: Program crashes when attempting to load registration key - iz2bkt - 01-20-2015 Hi, Trying to exclude the installation folder of IC7000BKT from Norton. Try this http://www.iz2bkt.com/forum/viewtopic.php?f=5&t=256. If that doesn't work, send me an email to the address of the full key with attacched the file IC7000BKT.INI file located in the installation folder. |
