CatBkt and BKTRemoteServer - Printable Version
+--- Forum: Icom (https://www.maniaradio.it/forum/forumdisplay.php?fid=9)
+--- Thread: CatBkt and BKTRemoteServer (/showthread.php?tid=218)
CatBkt and BKTRemoteServer - DD8JM - 12-01-2014
Hello,
I have a problem:
I use IC7100bkt, there goes even so far everything.
Now I have my IC7400 connected and configuriert with CatBkt.
Here I have the IC746 specified because there is no ic7400 in the list.
I use a Samsung S4 when I go online and BKTRemoteServer connecte, I get an error message on the computer:
Command not supported in any way by this RTX.
I've tried various transceiver, IC756, IC756Pro, IC7000 there is always the same error message.
If I Acknowledge the error at the computer goes everything, even the voice goes well.
The meeting with the voice over is a good thing, I've tried many programs but this program makes it first. Otherwise, I've been using Skype for voice transmission.
What I have to say, the program leuft not very reliable, there are a few crashes, can I receive voice but not send.
Error come on even when the reproduced connection and new connection again.
There is no connection to conditions, I have to finish everything and reconnect again.
Otherwise everything is very good.
My english is very bad, I hope you have understood it as far as what my problem is. :oops:
Best regards from Germany
Joerg de DD8JM
http://www.saure.org
http://www.dd8jm.de
Re: CatBkt and BKTRemoteServer - iz2bkt - 12-03-2014
Hi Joerg,
instead of CatBkt, try to use the program IC706_BKT, in configuration choose RTX=OTHER and CIV Address that of your RTX.
Re: CatBkt and BKTRemoteServer - DD8JM - 12-05-2014
Hi Mauro,
thanks for your help, the IC706 I had not tried, I'll try.
Thank you.
nice time
Joerg de DD8JM
Re: CatBkt and BKTRemoteServer - DD8JM - 12-07-2014
Hi Mauro
I IC706_BKT charged me for my IC7400 and there are no errors. Smile
But what is unfortunately no longer is the PTT since I can no longer select control over CAT here. :?
Unfortunately, PTT is no longer.
Is there still a solution for this.
many greetings
Joerg de DD8JM
Re: CatBkt and BKTRemoteServer - iz2bkt - 12-08-2014
Ok, now try IC7000BKT, in configuration change only the CI-V address.
