IC-7410 +CatBkt Split & VFOs - Printable Version
+-- Forum: CatBkt Cat Control using HamLib (https://www.maniaradio.it/forum/forumdisplay.php?fid=6)
+--- Forum: Icom (https://www.maniaradio.it/forum/forumdisplay.php?fid=9)
+--- Thread: IC-7410 +CatBkt Split & VFOs (/showthread.php?tid=209)
IC-7410 +CatBkt Split & VFOs - OH2RA - 09-22-2014
All!
I am trying to see if CatBkt would access VFO-A/VFO-B change correctly on my IC-7410. It seems that A=B is not working, the only way to set split is to use the "Split Tab", selecting the split button on the UI doesn't allow for me access VFO-A and B such that I can set the split naturally as it is sitting at the radio.
Is this a problem with all ICOM radios? Icom RS-BA1 remote control SW has similar problems.
Thanks!
Markku OH2RA
Re: IC-7410 +CatBkt Split & VFOs - iz2bkt - 09-24-2014
Hi Markku,
i do not know if it's a problem of the IC-7410, on other models it works, try to use IC706_BKT (download it from http://www.maniaradio.it) by choosing IC-718 and changing the address CI-V with 80.
