Removing blank mem locations - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Removing blank mem locations (/showthread.php?tid=20) |
Removing blank mem locations - Solus - 12-24-2010 I'm trying to figure out how to create a solid list of memory channels without blanks. I've added and removed memory entries and now want to create a list without blank spaces. Is this possible? I've tried remapping but this hasn't worked. I still have 5 entries, 7 blank, 3 entries, 4 blank, 6 entries, etc. Re: Removing blank mem locations - iz2bkt - 12-26-2010 Solus Wrote:I'm trying to figure out how to create a solid list of memory channels without blanks. this is only possible by choosing a sort of memory (by clicking on the column heading to sort) other than the #, for example by Frequency or Description or another, and then using the function remaps. Re: Removing blank mem locations - Solus - 12-26-2010 The problem I have with sorting is if I click frequency low to high, the stored frequency's are moved to memory location 43 and below, only if sorted high to low will they start at memory position 1. A major pain in the butt that I can't sort low to high beginning at memory position 1. |
