Memory sorting - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Memory sorting (/showthread.php?tid=2) |
Memory sorting - g0ifi - 10-02-2010 IC7000BKT is the best control program out there for the 7000, there is just one feature I would like: in memory management, it would be very useful to be able to sort memories by name or frequency. For example, you might have memory number 1: 144.525, memory number 2: 10.140, memory number 3: 7.100 and so on, but you want the memory numbers to ascend in frequency so that memory 1 is 7.100, 2 is 10.140 and 3 is 144.525 and so on. If you have hundreds of frequencies in memories it can take a long to time rearrange them. Something that does this job at the click of a button would be handy. Thanks for a great program! 73 Perry G0IFI Re: Memory sorting - iz2bkt - 10-02-2010 g0ifi Wrote:IC7000BKT is the best control program out there for the 7000, there is just one feature I would like: in memory management, it would be very useful to be able to sort memories by name or frequency. Perry, Thanks for your request, if possible, will be implemented in a future release. 73 de Mauro, IZ2BKT Re: Memory sorting - iz2bkt - 10-13-2010 g0ifi Wrote:IC7000BKT is the best control program out there for the 7000, there is just one feature I would like: in memory management, it would be very useful to be able to sort memories by name or frequency. This feature is available from version 1.10.0 with the Remap key. Re: Memory sorting - g0ifi - 10-20-2010 Thanks a million Mauro, this really makes it easy to tidy the memories. Re: Memory sorting - g0ifi - 10-26-2010 Mauro, two small problems: After remapping, the memories do not begin at memory #1, but instead they descend from #99. Also, I am getting duplicate entries in the memory list after remapping, or exporting and importing. I am sorry to report this. 73 de Perry G0IFI Re: Memory sorting - iz2bkt - 10-26-2010 g0ifi Wrote:Mauro, two small problems: I Perry, Thanks for the report, now checking and fix that bug. 73 de Mauro, IZ2BKT Re: Memory sorting - iz2bkt - 10-26-2010 g0ifi Wrote:Mauro, two small problems: Hi Perry, I tried but I have not found any bugs that you reported, however, I have corrected others. Your problems may be due to a loss of data between RTX and interface, try to go into COM configuration and change from mode 1 to mode 2 or vice versa. You can try the version 1.10.1 available on site http://www.iz2bkt.com. Thank you 73 de Mauro, IZ2BKT Re: Memory sorting - g0ifi - 10-27-2010 Mauro, The misnumbering from #99 down instead of from #1 up happened when remapping memories after deleting some unwanted entries from the list. However, all seems to be fine now. I installed the new version and everything works great. No duplicate entries when importing the files I saved yesterday. ![]() Thanks for your fast support for your program. |
