Error Message - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Error Message (/showthread.php?tid=19) |
Error Message - n1pd - 12-20-2010 Hello, Since upgrading to V1.11.0 I am getting the following message when starting IC7000BKT: "Error: access to boot.bkd was denied". I click ok and the program starts up. Also it loses connection with the radio quite often and requires closing the program and restarting. Thanks. Paul - n1pd Re: Error Message - iz2bkt - 12-20-2010 n1pd Wrote:Hello, Hello Paul, program IC7000BKT does not use files with the name boot.bkd, try this: 1 - Perform a Backup from the Utility Tab 2 - Uninstall IC7000BKT 3 - Manual delete IC7000BKT folder 4 - Install IC7000BKT Version 1.11.0 5 - Try if it works 73 de Mauro, IZ2BKT |
