Communication problem - COM error - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7100BKT Cat Control for Icom IC-7100 (https://www.maniaradio.it/forum/forumdisplay.php?fid=15) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=24) +--- Thread: Communication problem - COM error (/showthread.php?tid=189) |
Communication problem - COM error - iz2bkt - 07-21-2014 For communication errors try this: - Install IC7100BKT latest version from http://www.maniaradio.it. - check these settings in Icom IC-7100 Set-Mode->Connectors->CI-V: CI-V Baud Rate = Auto ( in some cases you need to select the speed set in the program ex. 19200 or 9600 ) CI-V Address = 88h CI-V Transceive = OFF - Install USB drivers Icom (download from: https://www.icomjapan.com/support/firmware_driver/) - From SerialPort drop-down list select the COM port with the description "SILICON LABS..." - try to change Serial Port Mode from MODE 1 to MODE 2 - try to use BKTRS232 driver: ![]() - try to switch ON/OFF the RTS and DTR signal - try to change BAUD speed - Verify that there are not running other programs that use the same COM port |
