Yaesu VR-5000 - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: CatBkt Cat Control using HamLib (https://www.maniaradio.it/forum/forumdisplay.php?fid=6) +--- Forum: Yaesu (https://www.maniaradio.it/forum/forumdisplay.php?fid=13) +--- Thread: Yaesu VR-5000 (/showthread.php?tid=18) Pages:
1
2
Yaesu VR-5000 - dg4dsl - 12-19-2010 I use a Yaesu VR-5000. The device does not respond to the control program. I have tried several settings without success. What can I do to? Thank you! Re: Yaesu VR-5000 - iz2bkt - 12-20-2010 dg4dsl Wrote:I use a Yaesu VR-5000. The device does not respond to the control program. I have tried several settings without success. What can I do to? Hi, Can you make sure your VR-5000 is set up at 38400 bauds, 8N1, and NO hardware handshake (no CTS/RTS) ? Re: Yaesu VR-5000 - dg4dsl - 12-25-2010 Does not work anyway. I have tried all possible settings. Re: Yaesu VR-5000 - iz2bkt - 12-25-2010 Sorry, this program uses HamLib to communicate with the rtx, try to see the HamLib forum http://sourceforge.net/projects/hamlib/forums/forum/25919 Re: Yaesu VR-5000 - dg4dsl - 12-29-2010 Thanks for the reply. I also use fldigi that works well with hamlib. There, the control works without problems. Re: Yaesu VR-5000 - iz2bkt - 12-30-2010 Please, how you've set fldigi? Thanks. Re: Yaesu VR-5000 - dg4dsl - 12-30-2010 I use standard settings of hamlib, set of fldigi. Use Hamlib Retries 0 Write Delay 70 Retry Intervall 1000 Post write delay 210 Baud rate 4800 Stopbits 2 Sideband Rig mode Re: Yaesu VR-5000 - iz2bkt - 01-01-2011 From the Alpha 20 version I've added new settings in the "COM setting", if you want to do some testing. Thanks. Re: Yaesu VR-5000 - dg4dsl - 01-01-2011 Thank you! It does not work with the new version. Do I need to change the "CI-V address" something? The entry is 0. Re: Yaesu VR-5000 - iz2bkt - 01-02-2011 The CI-V address is only used with the RTX Icom. |
