Kenwood TRC-80 no control of frequency. - Printable Version
+--- Forum: General discussion - Problems - Bugs / Discussioni - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=8)
+--- Thread: Kenwood TRC-80 no control of frequency. (/showthread.php?tid=141)
Kenwood TRC-80 no control of frequency. - ZS4L - 05-31-2013
Smile Hi All,
I am trying to get my Kenwood TK-80 / TRC-80 to work with the CATBKT software.
I have made an interface using the MAX-232 and 74C04 chips and it is communicating well.
I can change almost anything on the rig from the PC-but NOT the frequency , and I don't see the 'S' meter. The Frequency also displays ' OFFLINE'.
I really want to make this work for an article in our local Ham Magazine, so any help would be appreciated, I think it is in the software--I can send a copy of the TRC-80 command set if that is needed to verify the software.
Sometrimes, If I try the TS-570s software on the TRC -80 , it will read the frequency, but only when synchronising.
There are MANY of these rigs in South Africa, they are very good but hard to control, so the CATBKT software is a great help if working properly.
Many Thanks, de William , ZS4L
Re: Kenwood TRC-80 no control of frequency. - iz2bkt - 06-01-2013
Hi William,
CatBkt uses the set of commands included in HamLib, therefore, for implementations or changes you need to contact the authors of HamLib : http://sourceforge.net/projects/hamlib/forums/forum/25919
RE: Kenwood TRC-80 no control of frequency. - Elazar - 07-28-2019
Quote:
(05-31-2013, 07:11 AM)ZS4L Wrote: Smile Hi All,
Hi, I have the same transceiver, did you get it to work?
