Communication with other programs - Printable Version
+-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5)
+--- Thread: Communication with other programs (/showthread.php?tid=14)
Communication with other programs - iz2bkt - 11-12-2010
Using the DDE Protocol can I interface these softwares:
MultiPSK : multimode digital transceiver : http://f6cte.free.fr/
DXLab: suite with loggers, cluster. etcetera : http://www.dxlabsuite.com/download.htm
FLDigi: digital transceiver http://www.w1hkj.com/Fldigi.html
For proper operation of the Protocol DDE launch the program to interface when IC7000BKT is already running.
Direct Interfacing with BBLogger through BKTextension : http://www.bblogger.eu/
Re: Communication with other programs - ricshannon - 10-04-2012
I have tried the steps in your message from 12/11/2010 and can not make the fldigi program run. I also tried standalone ( no DXCommander) DXLab programs with no success as well. Is there a more detailed procedure for making these programs link to IC7000BKT ? Has there been interest form anyone using HRD's DM780 and Logger programs? They use TCP/IP local ports to communicate as well. The HRD rig control is very bad at this time and crashes frequently. I like IC7000BKT very much since it is stable on Windows 7, not much else is !!!!!. Let me know if you can help with these thoughts and issues.
___________________________
73 ricshannon (KJ4ZIH)
Re: Communication with other programs - iz2bkt - 10-05-2012
ricshannon Wrote:I have tried the steps in your message from 12/11/2010 and can not make the fldigi program run. I also tried standalone ( no DXCommander) DXLab programs with no success as well. Is there a more detailed procedure for making these programs link to IC7000BKT ? Has there been interest form anyone using HRD's DM780 and Logger programs? They use TCP/IP local ports to communicate as well. The HRD rig control is very bad at this time and crashes frequently. I like IC7000BKT very much since it is stable on Windows 7, not much else is !!!!!. Let me know if you can help with these thoughts and issues.
IC7000BKT emulates DXCommander and for the connection with the suite DXLab is not necessary any configuration.
Example:
1 - Run IC7000BKT
2 - Run DXKeeper
3 - Run SpotCollector
When you enter a new QSO will be set DXKeeper band and frequency shown in IC7000BKT.
When you double-click on a spot of SpotCollector IC7000BKT automatically set the frequency of the spot in the rtx.
Never run DXCommander but run instead IC7000BKT
