Scan resume - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC7000BKT Cat Control for Icom IC-7000 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5) +--- Forum: General discussion - Problems - Bugs / Generale - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=7) +--- Thread: Scan resume (/showthread.php?tid=132) |
Scan resume - kc7ido - 03-19-2013 When using the "SCANNER" with in the software, it seems as if it disables the scan resume within the radio setting. Then when using scan from the radio it will not resume and just stay on current frequency. It would be a good idea to script a SCAN RESUME - ON code when exiting the scanner mode. This will save a lot of hassle in the future. Thank you, KC7IDO Re: Scan resume - iz2bkt - 03-20-2013 Hi Mike, thanks for the tip. |
