CUT / PASTE multiple memory setting from Bank to Bank - Printable Version
+-- Forum: IC7000BKT Cat Control for Icom IC-7000 - will no longer be updated and will be replaced by CatBkt2 (https://www.maniaradio.it/forum/forumdisplay.php?fid=5)
+--- Thread: CUT / PASTE multiple memory setting from Bank to Bank (/showthread.php?tid=131)
CUT / PASTE multiple memory setting from Bank to Bank - N9XY - 03-11-2013
I am trying to figure out if it is possible to CUT and then PASTE multiple memory settings from one bank to another.
I can CUT one entry and PASTE to another bank. This works great. But need to highlight several entries in one bank, cut and then past them all into another bank.
Is this possible? If not, I hope this could be a new feature to consider adding to the software.
73
Michael
N9XY
Re: CUT / PASTE multiple memory setting from Bank to Bank - iz2bkt - 03-11-2013
I'm sorry but you can not because the program reflects real-time changes to the memory in the radio.
If you want, export the memory (in CSV format) make the changes with Excel or OpenOffice and re-import them in IC7000BKT.
