How to load the registration key - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: How to load the registration key (/showthread.php?tid=130) |
How to load the registration key - iz2bkt - 03-10-2013 Method 1: 1. Unzip the registration key file received by email in the program folder (default: C:\IZ2BKT\IC706_BKT Icom CAT Control). 2. Run the program IC706_BKT, the key will be automatically loaded and deleted from the folder. Method 2: 1. Unzip the registration key file <call.ic706_bkt.bkt> received by email in a folder. 2. Run the program IC706_BKT ( Version 4.0.5 or later, Free Key is not released for old versions ) 3. On Utility tab click on [Register the program] 4. On registration dialog click on [I have the key, load it] 5. Select the unzipped file in the folder used in step 1 and press [Open] 6. At the next run the program will load the key into its database and delete it from the folder. To check if the program is registered look in the title bar: ![]() ![]() |
