registration - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: IC706_BKT Cat Control for Icom IC-706 (https://www.maniaradio.it/forum/forumdisplay.php?fid=3) +--- Forum: General discussion - Problems - Bugs / Generali - Problemi - Errori (https://www.maniaradio.it/forum/forumdisplay.php?fid=4) +--- Thread: registration (/showthread.php?tid=118) |
registration - Glennp - 01-28-2013 I am having problem registering my program. The instruction state select the folder. What folder what is the folders name and were lo located. I do not understand saved to the point 1. what is point one. Any help explain this to me. Thanks Re: registration - iz2bkt - 01-28-2013 You choose the folder, such as C:\Temp or C:\Downloads, is not important as long as you remember where you save the file. Bkt to recall to Point 5 Re: registration - Glennp - 01-28-2013 What do you mean by BKT to recall Point 5 Re: registration - Glennp - 01-28-2013 IF I put the registration in any file how will the program find the registration code? Re: registration - iz2bkt - 01-28-2013 Be patient, as soon as possible, prepare the slides on how to perform the procedure Re: registration - Glennp - 01-28-2013 If I put code in any folder how will the 706 program find the folder? |
