Suggestion: Allow user to set when clock update occurs - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: Free Software (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: Suggestion: Allow user to set when clock update occurs (/showthread.php?tid=106) |
Suggestion: Allow user to set when clock update occurs - W6DTW - 11-26-2012 Hello Mauro, I have been struggling with a clock problem while using JT65-HF and a friend suggested BktTS. In struggling with this clock problem I realize that all time correction utilities will apply the correction at the :00 second point. Of course for JT65, this means that the correction occurs during the start of the receive/transmit period, which might affect the QSO. JT65 QSOs occur from :00 to 0:48 seconds every minute. If BktTS would allow the user to set when the clock update occurs, we could set the update to occur between 0:48 and 0:59 seconds, so that the correction does not occur during the receive/transmit period. Hope this suggestion is useful to you. Thank you for creating and maintaining this excellent software. ...dtw Re: Suggestion: Allow user to set when clock update occurs - iz2bkt - 11-27-2012 W6DTW Wrote:Hello Mauro, Hi, thanks for the tip, if possible, will be integrated in the next version. |
