BKtimeSync - Stopped working - SOLVED - Printable Version +- Maniaradio Forums (https://www.maniaradio.it/forum) +-- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=28) +--- Forum: BktTimeSync (https://www.maniaradio.it/forum/forumdisplay.php?fid=22) +--- Thread: BKtimeSync - Stopped working - SOLVED (/showthread.php?tid=485) Pages:
1
2
RE: BKtimeSync & Windows 10 64bit - Stopped working - SOLVED - Roy - 06-13-2022 (06-13-2022, 08:59 AM)iz2bkt Wrote:(06-13-2022, 08:17 AM)Roy Wrote: Thank you to everyone in the forum. Mauro, IZ2BKT Thank you for your prompt response. I made a mistake in the character settings. I'm very sorry because I didn't know how to use it. I have set the registry change settings for my PC. Now it works. Thank you very much for helping me. Now you can enjoy FT8. From Roy RE: BKTIMESYNC with Windows 11 PRO. - eliekadi@gmail.com - 03-28-2025 Hello Mauro, Bktimesync is freezing when connected to the GPS via USB to mt my Windows 11 Pro box. I just downloaded your latest version and still have the same freezing problem. The GPS is working ok with other software on the same port. Any solution from your side? Very 73 de Elie OD5KU RE: BKTIMESYNC with Windows 11 PRO. - iz2bkt - 03-28-2025 eliekadi@gmail.com Wrote:Hello Mauro,Hi Elie, Please start a new thread if it doesn't continue the current discussion, however I have moved your post to this thread try following these steps and see if it resolves. |
